people with hot start problems, READ
Old Oct 19, 2001 | 10:43 PM
breathment's Avatar
As with many people here, im havign troubles with my car wanting a few more cranks then usual to start when its warm. but in the morning it starts perfect.
im thinking that maybe it could be a temp sensor of some sort not working right, like in the morn or when the engine is cold, it realizes this and enrichens the fuel mixture, but when the engine is warmer, it requires a different mixture to start correctly, i had this problem with an old chrsyler and a throttle body temp sensor fixed it. and plus im having trouble with my car wanting to stay running in the morn, so im gonna change the sensor anyways.
but i thought changing the temp and air temp sensor might help with the warm start problems, im gonna replace them this weekend most likley so il post the results by sunday.
but im just curious of ur comments or experiences.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 20, 2001 | 02:39 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
If a sensor is INOP or is giving readings that are not in the normal range of what the sensor should be reading, the ECM will likely notice there is a problem present and flag a DTC on that particular componant. You should be getting an SES light if you have a dead or severely malfunctioning sensor......
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 20, 2001 | 05:30 AM
crucial's Avatar
I think he's right. If the CTS sensor doesnt read right when the car is warm, the ECM might make the engine start a little later. I've noticed that if my CTS sensor is disconnected the car will crank but it takes like 10 seconds (literally) of cranking to start. I've had it come unplugged while working that area a couple of times and it just take FOREVER to start after cranking.
1991 Z28 6.0 TPI
360 4 bolt main block, TrickFlow 23 degree heads, CompCams CS270HR cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, 2500 stall, bullet proof 700R4, aluminum driveshaft...
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
