tricks to getting old play dough off pistons?? :(
Old Aug 29, 2005 | 08:03 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I know, I know..."How F*ing stupid dude!". I had some play dough on one of the pistons to check piston/valve clearance. I got most of it off, and i figured Id be able to scrape the old crap off with a razor whenever. Well, the razor aint cuttin it. Any suggestions? Chemicals/techniques?
Old Aug 29, 2005 | 08:13 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
wire wheel, or rubber nubbed gasket remover that mounts to a drill or die grinder.
Old Aug 29, 2005 | 08:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
am i dumb or doesnt it dissolve in water, or dip it in gas for a bit...
Old Aug 29, 2005 | 09:08 PM
spills's Avatar
Car: 89 RS
I was kinda skeptical to take any kind of wire wheel or anything like that to the top of the piston. Didnt know if it would scar it or anything. Plus, I dont have an air compressor at my house
Old Aug 29, 2005 | 09:26 PM
Conv389drv's Avatar
Try some carb cleaner or other anti-gunk cleaning stuff, maybe let it soak in something overnight.
Otherwise just say F' it and run it!
Old Aug 30, 2005 | 10:19 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Just like my kids playdoh machines....playdoh in one end, fancy shapes out the other...
Old Aug 30, 2005 | 12:21 PM
sp63
Guest
Posts: n/a
considering how bad i feel right now , that actually made me laugh and feel good.
Old Aug 30, 2005 | 12:55 PM
koll's Avatar
Car: 1991 Pontiac T/A Vert
I would say run it. Im sure it would burn off rather quick with no bad side effects.
Old Aug 30, 2005 | 01:29 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no, you got it.
play-doh is water soluble... just toss it in a bucket to soak, and it'll be off easily.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Oct 5, 2015 06:23 PM
RS Reaper
Sep 27, 2015 07:04 PM
