Serpentine conversion HELP FAST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 20, 2001 | 07:23 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Im doing the serpentine conversion on my car 87 Iroc l98. I got the pass side bracket on with some emission line problems but I think I have it figured out for now. ON the Driver side I can't put the bracket on because the fuel lines are in the way. I need the car Monday. What Do I about the Fuel lines ?????????????????????????????????????????????//
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
Old Oct 20, 2001 | 08:48 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
You need a pair of fuel lines specific to the serpentine system. They are much shorter than the lines used for the v-belt system and route the lines between the alternator and valve cover. Sorry, but it looks like you won't be using your car Monday....
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig) with 50-hp nitrous: 12.043 @ 112.86 mph.
ATI D1SC (10-psig): 12.056 @ 116.62 mph.
All stats are altitude corrected for 3,100 feet using NHRA's Altitude Correction Table.
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Oct 20, 2001 | 09:09 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
the 88-later setupsplits the fuel linesonegoing above the alternator bolt and the other below.you couldbend the originals but they may crack then you are back to square one,or go the the auto parts store and get hi pressurehose cut the fuel lines and run soft lines to the originals until you get the correct lines coming from the plenum.dont cut the hard lines going along the frame rails to the pump or you'll be screwed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 20, 2001 | 09:15 PM
camaro6spd's Avatar
yes, i put in a 90 305 in my car and it had all the acc and the serpintine belt. For now, i bent the hard lines so that that i can atleats move teh car around, just be sure not to bent it too much in one place.
1987 Black 305 TPI 5spd IROC, seems to be fully loaded, but can't find RPO codes.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Oct 20, 2001 | 09:56 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
damn. I was afraid of something like that. Wish I would have known before I started. Does gm still make these lines? Or will I have to buy them used? Thanks for the help.
if I did the rubber line thing for now How safe is that really? I have no idea of the pressure that goes through there or anything. I got to get to school on monday and its 25miles away from me and I dont want to be stranded with a burnt up car.
Also If any of you did this switch and kept emissions what did you do with that metal pipe that runs from the back of the block, along the valve cover and into that diverter valve thingy on the passenger side??? It is too long for the new valve.
[This message has been edited by john5.7 87Iroc (edited October 20, 2001).]
Old Oct 20, 2001 | 11:25 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by Willie:
</font>
Are these the ones # 43 and 44 in the pic?????
What about #39 and 40 do I need those too?? Or will mine I have now work?????
Old Oct 21, 2001 | 03:10 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, GM still has them available, and if I remember correctly, they are about $12 each.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Linson
Oct 24, 2025 02:00 PM
jrdturbo
Mar 31, 2016 02:58 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
