I need cam specs
Old Oct 21, 2001 | 03:55 PM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
I need cam specs
I was wondering what kind of cam specs I should look for. I have the stock L98 listed at the bottom and I'll be getting a 3 angle valve job. It's my daily driver but I want something to give me a nice hp boost. Would a ZZ4 cam be too much? Too little? If ZZ4 isn't right, what specs should I look for. Being a novice, I need some specific suggestions. Thanks...
91 TA 5.7 TPI Automatic.
w/WS6 and 3.23 rear.
K&N Cone Air Filter (at the end of the plastic tube),Hypertech Coil, Moroso Blue Max Wires, Bosch Platinum plugs,JET 180*fan switch, JET air foil, Dual cats with Flowmaster 3" exhaust, GM Performance PROM, Complete PST components on front suspension, Spohn LCAs/Panhard bar.
My car only uses Mobil 1 transmission fluid, oil, and differential fluid.
Old Oct 21, 2001 | 04:54 PM
Jester's Avatar
The ZZ4 cam will be an improvment over stock, but not a large one. Alot of prople have had great results with the LT4 HOT cam, I would recommend going that route.
Old Oct 21, 2001 | 05:33 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
If you plan to stick with stock runners and gearing I would not go with more duration than the ZZ4. It will keep the powerband closest to what a tpi can best utilize.
Jorlain
Oct 8, 2015 01:57 AM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
masonta
Sep 1, 2015 06:40 PM
