Im out of ideas. Could the engine not being ground to the frame cause it not to start
Old Oct 16, 2001 | 01:07 PM
Surreal86z's Avatar
I still can't get it to do anything. I switched my carb with another 650 dp that i have and still nothing. Played with the distributor when i was starting it and nothing. The only thing I know i didn't do on the engine was ground it to the frame, but I don't see how that would keep it from starting.
Im gonna email MSD to see if anything on the distributor could be bad, but the only thing to go bad is the magnetic pickup. I dunno...
Thanks,
Scott
Old Oct 16, 2001 | 01:20 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
yep, grounds are important on aftermarket igntions. I have 2, one to each head. And a third from the distributor to the frame (and coil)
Old Oct 16, 2001 | 01:46 PM
Surreal86z's Avatar
That didn't work. 2 guage ground, bout 10" long from the firewall to the back intake bolt, still didn't even try to start up. I never did that on my other car with the same setup, I only had charging problems with the battery
Old Oct 21, 2001 | 06:59 PM
gmanuel's Avatar
Hey there is two reasons an engine will not start. GAS and ELECTRICAL. Have you verified that there is gas getting into the engine. To check look down the carb and operate the gas pedal. You should see gas being sprayed into the primary side of the carb. If there is gas then you have to check for spark. There is a tester that you can put on the end of the spark wire that clips to ground on the engine. Crank the engine and see if you can see a spark jumb the gab in the tester. I had a light blue spark an one car, that did not produce enough spark to fire the gas.
83Z28, 350,5speed,TTops,Heddman Shorties, mild cam, K&N air filter.
Old Oct 21, 2001 | 07:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is the engine cranking or is there nothing. I would double check the grounds as this has happened to me several times where the ground wire to the battery wasn't completely tight. If the engine cranks it takes 3 things for it to run. Air/Fuel Mixture, Compression, and spark. To check for spark put a timing light on each individual plug wire to see if they are in fact working. Maybe spray some starter fluid or put a little bit of gas in the carburetor to see if any thing happens. And maybe do a compression check if necessary.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
