Another Question on my SERPENTINE COnversion!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 21, 2001 | 08:15 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I am haveing trouble using the alternator brace that is supposed to go from the back of the alt to the 1st header stud. I either have the wrong alt or wrong brace. I can fit the alt on the Driver side bracket fine. Tell me if Im wrong but the brace is supposed to go over the stud on the back of alt that is also shared with the wire from the positive battery cable. But when I put the brace over this, It wont reach the Header stud. The brace ends up about 1/2" too short. I know there is another hole on the back of the alt that you can put a bolt in but that hole, with the alt already mounted, is on the bottom to where it is right next to the head where it would be impossible to get to.
So do I have The wrong alt, Wrong brace, Both, Or am I just missing something easy.
By the way The brace I do have is 8 1/4" long from tip to tip
SECOND QUestion. The thick negative battery cable that used to be on the Old alterantor brace. Where does this now go to??????????????????????????????
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
evilstuie
Jan 9, 2020 08:29 PM
lt1z350
Aug 28, 2015 05:57 AM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
