Oil leak between bell housing and dust cover
Old Sep 1, 2005 | 02:02 PM
gmt830's Avatar
Car: 1993 Chevy Caprice
Brand new motor installed not yet fired. Filled it with oil and got a slow leak between the the bell housing and the dust cover. Not trans fluid its the 10 W 30. Is the rear main no good? What could cause this? I don't want to fire the motor and blow a seal. Any ideas?
Old Sep 2, 2005 | 10:35 AM
Damon's Avatar
Might be a rear main. Might be the oil pan gasket. Usually leaks back there happen when the motor is running becuase the oil level isn't high enough to just run out of the back of the motor without the crank whipping the oil around. Yank the 6 bolts from the dust cover and have a look.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
sreZ28
Aug 14, 2015 07:48 PM
drathaar907
Aug 6, 2015 04:20 PM
