reservoir not draining
Old Oct 22, 2001 | 01:03 PM
formula14's Avatar
My coolant doesn't drain back into my radiator. Ive checked the hose and cleaned the reservoir out to make sure no gunk was in there. ive heard that this means i have a vacuum leak somewhere. What do you guys think?
[This message has been edited by formula14 (edited October 22, 2001).]
Old Oct 22, 2001 | 02:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Usually that means either that you have a cooling system leak, or that you need a radiator cap.
ICON Motorsports
Old Oct 22, 2001 | 03:27 PM
formula14's Avatar
i just went and looked. There is a small leak where one of the lines threads into the radiator. what can i use to seal that up? My dad says to use bars leak but ive heard some bad stories about it.
Old Oct 22, 2001 | 05:14 PM
zslug's Avatar
Only problem with BarsLeak, or any other stopleak type product is, it can't tell a leak (that should be filled) from a partially clogged water passage (which shouldn't be)
Zslug
May the road rise to meet your treads...
'84Z, 5sp, stock 305, Edelbrock intake, GTA wheels
Fireslash
Apr 11, 2016 06:43 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
raymondandretti
Sep 27, 2015 06:43 PM
bigcheeseburger
Sep 17, 2015 03:17 PM
