IS THIS A GOOD ENGINE?
Old Oct 21, 2001 | 06:52 PM
tennysonmr's Avatar
I'm a relative novice when it comes to engines and I was hoping you guys could help me out. I recently purchased an '87 Formula in which the previous owner pulled the stock 305 and put in a 350. I finally found all the engine casting numbers and codes and was hoping you guys could tell me if this is a good engine to build up. The engine block casting # is 14093638. The engine suffix code is V0204TPA. The head casting # is 14102193, and I also found this code on the back of the block by the drivers side, GM 5.7LG SGI. Any info would be greatly appreciated.
Old Oct 21, 2001 | 07:23 PM
Changa2's Avatar
I'll leave the quality question to somebody that knows but you can try the following thread for a basic description of the block and heads.
http://www.mortec.com/castnum.htm
Old Oct 21, 2001 | 08:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like a 350 TBI long block...
A block is just a block, within certain limits. That one is probably not a roller block but might be a 4-bolt-main one On the other hand, those are among the worst 350 heads there are, and I doubt the cam is a very strong runner unless the previous owner upgraded it.
ICON Motorsports
Old Oct 22, 2001 | 06:42 PM
tennysonmr's Avatar
I appreciate the responses. Anyone else?
Reddeath210
Oct 6, 2015 08:20 AM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
