Possible to make power to 7000RPM with fuel injection?
Old Oct 17, 2001 | 05:52 PM
Dan87IROC-Z's Avatar
And I mean real fuel injection, not some TBI knock off. I was thinking of building a 377 fed with a Mini Ram, big cam, AFR 195s, big exhaust and such. Would it be possible, with porting the MR to get it to pull to 7000+ RPM? And I am NOT considering getting a carbed POS engine, so please don't suggest it.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Oct 17, 2001 | 06:17 PM
Slow Iroc's Avatar
Sure, it is def. possible. Look at the Ford guys, 8,000+RPM motors. Of course, if you want to make power like that, make sure your car isn't a fat elvis, or prepare for bogging and stalling.
Old Oct 17, 2001 | 06:48 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
The main issue is preventing frictional losses from exceeding the HP benefits that higher rpm provides. Normally this requires something other than standard strokes. Winston cup motors use 400 bore diameter and 327 strokes to make 355 cubes.
The other issue is how you going to meter fuel. The factory ECM for LT1 has no fuel maps above 7000 rpm. A dfi is required.
Old Oct 17, 2001 | 07:24 PM
Tas's Avatar
Tas
http://www.holley.com/HiOctn/ProdLin...901-101-1.html
-Tas
'89 Formula WS.6
Got Beach?
Old Oct 17, 2001 | 07:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. Look at the Accel Pro Ram.
ICON Motorsports
Old Oct 18, 2001 | 06:32 PM
What do you mean make sure its not a fat elvis?
L98 TPI 350 (5.7L)
Old Oct 19, 2001 | 05:02 AM
ronterry's Avatar
Car: '94 Corvette
MayBBe the engine had to MMany Cheeeseee Burgers.
Old Oct 19, 2001 | 05:56 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
A Miniram should have no problem supporting 7,000 rpm since it is an "untuned" intake like a typical carb intake manifold. You will need to consider an aftermarket ECM such as DFI, as neither MAF or SD have fuel correction tables that exceed 6,400 rpm. Just make sure that the DFI unit is capable of high rpms.
Alternatively, if you got into the Source Code of the SD ECM, you might be able to expand the VE and PE Fuel tables to provide correction at that level. But this level of change is beyond most custom prom writers. Most just use the stock GM eproms as a "base" and only change the table entires...which are limited to 6,400 rpm. So with the stock ecm, even with a custom prom, you'll be flying blind after 6,400 rpm.
Old Oct 19, 2001 | 04:25 PM
Slow Iroc's Avatar
I mean reduce the weight of the stock Fbody if it's a standardly equiped T/A or Z28. These cars are freggin' HEAVY! To continually make power till 7 grand he's going to have to give up some low rpm power, period. If the car is too heavy the engine may laugh at the task of moving it if given even just slightly too much air, in the form of bogs or stalling. Doesn't happen with EFI motors? LOL the IAC valve doesn't adjust that quickly.
Old Oct 19, 2001 | 10:44 PM
Altight, thanks guys. Where do I buy a DFI and what does it cost? Also, what are some things I can do to lower the weight? I do plan on having my 377 be an aluminum long block.
L98 TPI 350 (5.7L)
Old Oct 20, 2001 | 12:10 AM
91z4me's Avatar
The rotory motors could rev even higher than that I think. Don't help but it has been done from factory.
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
Old Oct 20, 2001 | 04:10 AM
Slow Iroc's Avatar
Actually, unless you really need that aluminum block, I think an iron block would be better. Iron provides much better sealing power... unless you like doing head gasket jobs?
As far as reducing the weight, a lot of guys if they absolutely NEED an Fbody will strip it of interior peices, and options to reduce the weight. I don't agree however. I rather drive a car that's lighter because the overall construction is lighter than to drive a stripped down car.
From a post I started earlier, I guess the Nova is the big ticket for me... others felt S10's of Vega's would work well. Unfortunately, remember if powertrains produce the same amount of power, the lighter car will be faster... why give yourself a handicap is how I look at it. Ford's motors are crap, their interiors suck, but their cars are lighter... ultimately, that will make them faster given the same *OVERALL* (not peak) power output.
Old Oct 20, 2001 | 09:28 AM
BlakCamZ28's Avatar
In order to drop some weight a big help is the tubular K-member. You can also convert to manual steering from an S-10. There is all this nice heavy insulation under the rug of the car that can come out as well. How big are you into music cause those speakers and radio are weight also. I'd move the batter to the back of the car to have better weight distribution. Windshield washer resevior....who needs windshield washers anyway. Fiberglass is always good. You can get fiberglass hoods and fenders and front clip. I think doors are also available but i wouldn't recommend unless you have a cage in the car cause some a$$hole might t-bone you or something and you'd be in trouble.
Old Oct 22, 2001 | 07:12 PM
Yeah, I already have pulled out some un-necessary stuff from my car. Like the all the AC crap and the windshield washer fluid tank. I really don't want to strip the car down, I like having some convienence features there. I would like to get a fiberglass hood, aluminum radiator and get rid of the big amps and speakers in the back of the car and replace them with some regular 6 x 9s. Anyway, thanks again!
L98 TPI 350 (5.7L)
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
