Mega 305
Old Oct 20, 2001 | 10:08 AM
E-Z Rollin's Avatar
Mega 305
Just to show what can be done with a 305,here's specs on one from an article in H.P. Chevy Dec.93:305[.030 os.]AFR alum.heads[1.99/1.55]appox. 9/1 cr. cam 218/223@.050 lift 460/470 cl.110 1.5 ratio rockers. Edelbrock RPM intake and Holley 650 dp carb. Horse Power 387 @ 6000 rpm's Torque 367.6 @ 4000 rpm's. Now these were big heads for a 305 [ int.vol.190]but a good set of gm.alum. or after market with 1.94/1.50/170cc/9.5:1 comp. should make some decent hp. So don't despair if you have a 305 !
Old Oct 21, 2001 | 03:29 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
someone guestimate the HP of this combo, 305, AFR heads, 9-10:1 comp. crane 2032 roller cam 214/220 ~.48x"/.494" lift int/exh with 1.6 roller rockers, probably LT1 style intake manifold(EFI), hooker LTs. Will there be enough cam? I want ~340-350hp.
Also a stock TPI or Siamesed Base and 1 5/8" mildly ported edelbrock headers.(I currently own these pieces so..) If you think either of these would be better. No suggestions about low end torque please.
[This message has been edited by Beast5spdGTA (edited October 21, 2001).]
Old Oct 22, 2001 | 01:52 AM
82resto's Avatar
That is pretty darn impressive....
I've always thought that if you had a perfectly good 305 already in your engine bay, and it didn't need to be replaced, why not just make it nearly 400 horsepower? Is someone going to think your engine's weak if it's only 367 horsies? Probably not...
Jon
89 GTA
Beautiful Gunmetal gray, LB9 305 and T5 tranny. Only 60,000 miles!
Dual cats, 3"flomaster
Accel 300+ Ignition, wires, cap, coil, etc
Airfoil
KN Airfilter
Removed Screens on MAF
SLP 1 3/4 headers
No Smog/AIR system
Old Oct 22, 2001 | 09:22 AM
E-Z Rollin's Avatar
You should always think what the intended use of an engine before building it,not every one needs or wants a 400+ hp eng. I could have built a 350,which is what I'd recommend be cause it has more cubes and cheaper to build,but I had a 86 305 block already and got a great deal on a new set of gm alum. heads and fft trw .030 os pistons.I decided a horsepower per cu.in. was enough for every driving and good performance in a S-10 2wd blazer. Can't wait to finish the project just to see how it performs.
Old Oct 22, 2001 | 04:10 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
ok, so how much do those heads/cam/rocker/intake cost?
Old Oct 22, 2001 | 07:55 PM
Engine: LS7
Heads/cam/rockers ~$2000 carb intake is like $180 i think, LT1 probably about $350+ assuming you have some way to get a custom chip for cheap, otherwise add $250 for burning your own chips and alot of time.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
