350 ppm of Hydrocarbons to pass..emission help
Old Oct 22, 2001 | 05:40 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Limit Reading Result
HC ppm 108 435 FAIL
CO % .60 .33 PASS
NO ppm 1161 410 PASS
@1497 RPM -valid
Dilution - valid
AIR Injection PASS
EGRsystem PASS
PCV PASS
Catalytic Converter PASS
Fuel Evap system PASS
TAC N/A
Gas Cap PASS
Visual Inspection FAIL = condensation is coming out of the pipes..I still have run it longer to see if its really coolant
The catalytic hasnt been changed in 3 yrs or longer and the car was tested almost "just started up in the morning"cold.
Would a higher temp thermostat help out and/or a catalytic converter??
Im also getting a Idle Speed Control circuit error but since the test is not on idle I dont think this is a problem..
car is an 86 Cadillac 4.1 liter
Daz
Old Oct 22, 2001 | 08:24 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Hey Daz..I don't belive they ran it cold...that could be the whole problem.
And they failed it for condensation out the pipe?? WTF kind of test do they do there?
Almost every car sitting in a stall with the engine running will produce some sort of water out the pipe, its called hot air in cool pipes..
You can hide death with a new cat, so maybe thats in order.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Oct 22, 2001 | 08:27 PM
Enkil's Avatar
The car should be fully warmed up before it goes in for emissions testings. The cat needs to be at a certain temperature before it can start doing it's job.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Oct 22, 2001 | 09:03 PM
watchmesuck's Avatar
I passed emissions right after I got a brand new catalytic converter. The car was tested pretty cold as well.
GTAman
Jul 3, 2024 07:29 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
