350 TPI high oil pressure but runs fine???
Old Oct 22, 2001 | 02:48 PM
Garett92Z's Avatar
Hey guys!
just got my new 92 Z and I love it except that the oil pressure gauge goes up pretty hihg... about 3/4 of the way high! Now the engine is throwing a code so I think it'll be somethin simple, maybe a MAF problem ro something? car is in need of a good tuneup.
well anyways... any of you want to take a stab at what might be causing the oil pressure to be so sporadic? car is in good condition and has about 100 000 miles on it.
thanks again
garett
Old Oct 22, 2001 | 03:32 PM
rezinn's Avatar
The guage should go up that high, higher at higher rpms. It should fluxuate a bit. Check the code, the front page of thirdgen.org will show you how.
Just so you know, your MAF and oil pressure are completely unrelated.
Old Oct 22, 2001 | 03:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
A good rule of thumb is 10psi per 1000rpms.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 22, 2001 | 09:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
3/4 of the way on the oil pressure gauge is 45 PSI, and that is perfectly normal.
You dont have a MAF on a 92 Z28, its speed density.
Do the tune-up stuff as shown in the tech article "Suggested mods for thirdgen TPI cars" and you should be in better shape.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 22, 2001 | 10:36 PM
breathment's Avatar
high oil pressure is alot better then low oil pressure,
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
