Bad Thermostat?
Old Oct 21, 2001 | 02:51 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Bad Thermostat?
This car is not being nice. First the timing thing (which I still haven't figure out) and now there's coolant leaking from the uppper rad hose. The upper hose gets hot and then leaks at the end of the hose where the thermostat housing is. Lower hose stays cold.
Symptoms of a dead thermostat?
Stock 2.8 MPFI auto w/ Flowmaster 80 Series, More to come......
Pioneer DEH-11
Targa E-910 7-Band Equalizer w/ crossover
2x 10" Pioneer subs powered by 300 Watt Jensen amp
2- 6x9" Pioneer (rear)
More to come..... (hey, i dont got a job yet)
Old Oct 21, 2001 | 02:56 AM
rezinn's Avatar
Its really hard to ruin a thermostat, if you suspect it may be bad, consider it bad and replace it. Its a ten minute job that costs five bucks. I would just check to see if the hose is secure though.
Old Oct 22, 2001 | 01:48 PM
zslug's Avatar
Unless I'm very confused (which could be) the engine coolant flows from the thermostat, through the upper hose, through the radiator, and back to the engine via the lower rediator hose.
Something's not flowing. I doubt it's the thermostat, but since it's the cheapest and easiest thing to check, pull it out and see if you get flow restored through the system. If so, you just got lucky; get a new thermostat.
If not, head for a radiator shop!
Zslug
May the road rise to meet your treads...
'84Z, 5sp, stock 305, Edelbrock intake, GTA wheels
Old Oct 23, 2001 | 12:38 AM
89V6FBIRD's Avatar
Is it really that order?? I always thought it went from the radiator to the upper hose to the thermostat thru the engine then out the bottom. But then if the top gets hot and the bottom doesnt......?
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Stryker412
Sep 20, 2015 06:59 PM
gta892000
Sep 16, 2015 12:40 AM
85Special
Sep 3, 2015 04:21 PM
