Newbie Q - Removing the rotor
Old Oct 22, 2001 | 04:40 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I have the cap off and i can't figure how to remove the rotor. Do you just pull it off? I don't really want to break anything. Haynes said it was held in by 2 screws but it also said the cap was secured by latches. I have a 350TPI. Thanks
1989 Formula 350
Old Oct 22, 2001 | 04:49 PM
Jester's Avatar
The cap should be held on by 2 screws, but the rotor is just a press fit. That means you just pull it off...it may take a bit of yanking they can be tight.
Old Oct 22, 2001 | 04:51 PM
Thanks for the quick reply!
1989 Formula 350
Old Oct 22, 2001 | 10:34 PM
86TransAmTPI's Avatar
Some caps are held in place by 4 screws and some others are held by 4 screw type latches,as far as the rotor goes,once the cap is off,the rotor should be held in place by 2 screws.Un-do the screws and the rotor should come right off.Its the person experiences i have had on 3 Trans Ams.
86 Trans Am 305 TPI,Bored 30 over,Blower Cam,Fordged Racing Pistons,High Volume Oil Pump,3" Flowmaster Exhaust,Hypetech Coil,Acell 300+ Race Wires,Bosch Platinum +4 Plugs.Best Et was 12.5 with a Paxton.
Old Oct 22, 2001 | 10:53 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
theres no screws on your 89 on your rotor. I have the same car. Just get a set of vise grips and rip it off. My old one broke into 3 pieces trying to get if off.
Old Oct 23, 2001 | 09:21 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Just to put it in one post in case someone is confused by this post, there are 2 cap/rotor styles used in thirdgens.
The coil in cap cars (carbed and early TPI) have 4 latches around the cap, and the rotor has 2 screws holding it down.
The external coil cars have 2 screws holding the cap down, and the rotor just presses on, no fasteners. Sometimes these can be sticky, but they do just pull straight off if you try hard enough.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.7 @ 93.6
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Oct 23, 2001 | 10:53 AM
chevyboy07 91's Avatar
use the "nail puller" side of a hammer to hook under the rotor and just work it off/pull as needed. It really works like a charm.
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheExaminer
Sep 6, 2015 11:40 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
