afr head question
Old Oct 24, 2001 | 02:52 AM
chrisfrerick's Avatar
afr head question
i just bought a set of afr heads. i talked to afr and told them the mods that were done to my car and i wanted it to be emissions legal. i have an 88 iroc 350 and my mods are in my sig. is there any reason why they chose 64cc for cylinder volume. i bought the 190cc
88 iroc 350 auto slp 1 3/4 headers,slp cam with .487lift,tpis intake manifold,tpis runners,msd ignition,k&n filters.
thermomaster chip with fanswitch and 160 thermo,transgo prokit with shift kit and upgraded torque convertor.factory 2.77 borg posi rearend koni sport yellow shocks and eibach lowering springs
Old Oct 24, 2001 | 08:20 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Sounds like they set you up with 64cc heads to keep your compression ratio the same as stock with the AFR's installed.I would guess that your stock L98 heads are 64cc also,at least if I remeber my friends right when we pulled them.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Oct 24, 2001 | 10:24 AM
85transamtpi's Avatar
64cc is your combustion chamber volume. The intake runner is still 190cc, i would think. You are just a little confused. 190cc combustion chambers would give you like 2 to 1 compression.
peace
evilstuie
Jan 9, 2020 08:29 PM
CRFred
Feb 7, 2016 11:39 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
