IGNITION TIMING
Old Oct 23, 2001 | 03:31 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
IGNITION TIMING
I have a 92 RS TBI and recently installed a Crane CompuCam 2031 rollercam. I installed it straight up since I didn't have a degree wheel. While adjusting the timing I noticed that the car drives best at around 10-12 deg BTDC with the EST disconnected. Does that sound right considering that the factory timing was at 0 deg with the EST disconnected? The car doesn't backfire or anything. If I bring it lower than 10 deg w/disconnected EST then the car hesitates at lower RPMs. Do I have to degree in the cam? Any help will be appreciated
92' Camaro RS 305 TBI
Best 1/4 mile - 14.6 @ 96 mph w/NO NOS
Best 60' - 1.9 secs
Check it out
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=4860
Old Oct 23, 2001 | 04:00 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
degreeing the cam is not directly assocated with timing advance. It is valve timing not ignition timing. The former is the relation ship between the valves and the pistons as they go through the 4 cycles. The latter is the relationship between the time the spark is triggered and the location of the piston as it goes through the 4 cycles.
If you can pass emission with that much timing i say keep it there.
Old Oct 24, 2001 | 06:41 AM
pwdbychevy's Avatar
The car runs fine but doesn't that sound like to much timing? When I plug the EST back in then the timing jumps to about 20-22 deg. I wonder if the markings on the Fluidampr are wrong.
Best 60' - 1.9 secs
Check it out
Old Oct 24, 2001 | 09:53 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Its a lot of initial. but it depends on what the ecm is doing as to how much total your getting. All aftermarket cams like a little more inital advance. 10+ degrees is a little more than I would think, but rarely are fluid dampers the fault.
Old Oct 24, 2001 | 10:48 AM
pwdbychevy's Avatar
Well the car seems to like the timing so I guess if it ain't broke I won't try to fix it which is contrary to what us Gear-Heads like to do anyways "IF IT AIN'T BROKE DON'T TRY TO FIX IT. JUST MAKE IT BETTER!" Thanks for the input.
Best 60' - 1.9 secs
Check it out
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
