where do i hook up a manual oil pressure gauge to
Old Oct 24, 2001 | 07:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
I have an auto meter manual gauge and need to have it hooked up temporialy to see where the pressure is at onmy new crate motor. i dont trust the factory one.
Old Oct 24, 2001 | 07:47 PM
Vader's Avatar
There is a 1/8" NPT port on the rear ledge of the case, near the distributor. That connects directly to the oil galleries.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 24, 2001 | 07:50 PM
BOTTLEDZ28's Avatar
Transmission: A4
so i can just take the plug out and install the pressure fitting
Old Oct 24, 2001 | 08:00 PM
Vader's Avatar
Correct. For a temporary connection, a little PTFE tape will work fine, but if it were a permanent installation, some pipe sealant would be best.
Later,
Vader
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
ChevyZ71
Aug 13, 2015 07:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
