Starting up stored car(IROC)
Old Sep 6, 2005 | 08:40 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Have purchased a 1985 IROC-Z that has been sitting in a garage for 2 years. Was in running condition when stored. I Have changed oil and filter, squirted oil in all spark plug cyl holes, will install new plugs, have drained old gas and put new in with HEET water treatnment. Also installed new battery. I am looking for suggestions as what to do further. I am concerned about injectors, computer,etc. Any help would be appreciated. Thanks,BADMAN
Old Sep 10, 2005 | 03:58 PM
Vader's Avatar
Check the air filter and intake tract for univited guests, "forcibly evacuate" them, then start it. Allow it to warm up before moving it if at all possible. Monitor for leakage, unusual noises, and anything abnormal while warming up.
Be very wary of the brakes. Check tires thouroughly for checking and cracking.
Plan on changing all fluids before you're finished. The coolant can't be good unless the system was flushed just before storage. The transmission oil should be changed as well. Check the axle oil level.
The ECM (computer) won't suffer from just sitting there for years. The injectors may have tip deposits from the fuel that evaporated after its last run, but wait until you've run it for a while before considering any action, unless you have an obvious problem.
Plan in changing the fuel filter soon, and possibly twice if the tank shows signs of contamination.
Anything else that arises can be addressed as you discover it. We'll be here.
Old Sep 10, 2005 | 04:00 PM
Vader's Avatar
Incidentally, Welcome Aboard!
Old Sep 10, 2005 | 07:57 PM
corky9491's Avatar
Car: 83 Berlinetta
Engine: 355
Transmission: TH350
I remember reading somewhere that you should start the car in neutral and let it run in N instead of park for better lubrication, otherwise you will burn up the clutches, feel free to correct me if I'm wrong.
Old Sep 10, 2005 | 08:02 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I will have to check but, I think park offers the same fluid flow but, I will have to check
Old Sep 10, 2005 | 08:46 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Hmm the pump runs in one of the settings, and in the other it doesn't. I don't remember which is which though. I actually thought the pump ran in park, and not in neutral, but someone else would probably know better than I would.
Old Sep 10, 2005 | 11:00 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
a car sitting that long will have all the oil galleys dry. I would pull the distributor and oil prime the engine to make sure there is fresh oil going to the bearings, lifters, and rocker arms on start up.
Old Sep 10, 2005 | 11:41 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
the pump runs all the time it is driven from the lugs on the tc. it doesnt mater if it is in park or neutral. i say park just incase some of the clutches are stuck together the car wont take off. they wont burn up the clutches arn't applied. sounds like you took care when storing so you should be ok. good luck
Old Sep 11, 2005 | 06:45 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks for all the advice. Unfortunaly the fuel pump is not working. Have to drop tank and replace. I did prime engine oil by rotating pump gear through dist. inlet. hope to have running in about a week.
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
