casting number
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
casting number
I have a old engine dipstick on driverside with oldschool crank
casting#is K1206C8C or K1206080 under its written 791310634
can you help me to identify my engine???
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
www.mortec.com should help
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Those look more like stamping numbers. For casting numbers you have to look on the rear of the block near the distributor.
ok..
those numbers were in the front..passenger side..over the water pump near the head.
on the rear the only number i see is 350 very big thats it.
Engine: 383 Carb
Transmission: 4L60
This page tells you where to find it: http://www.mortec.com/location.htm
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
K1206C8C
K = St. Catherines, Ontario engine plant
1206 = December 6
C8C = 1979 350 called a LM1. Vin code was L. Had a 4 barrel. Originally in F-body or Monte Carlo
791310634 is the last part of the original car's VIN number
1206 = December 6
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Sep 27, 2015 08:37 PM
