engine block 5.7LG?? Help!!
Old Oct 24, 2001 | 01:35 AM
92zeddar's Avatar
14573638 is the casting.. I can't find any info on that casting??
please help?
will this engine work in my camaro because it might be flat tappet engine?
92 z-28 G92 black with white racing stripes.
Dynomax cat back
Ram air
305 5 speed, underdrive pulleys and TB by pass
https://www.thirdgen.org/rides/rideimages/92_Z.jpg
Old Oct 24, 2001 | 04:22 AM
poncho9789's Avatar
I can't runn the casting no. for you but if the intake is off or you can take the valve covers off you can shine a flash light down in to the lifter valley and see the lifter retainers then you will know for shure if the engine is a roller or not. Also what did the engine come out of?
Old Oct 24, 2001 | 07:46 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i cant find the casting number at mortec. more than likely that is a late model block?
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
Old Oct 24, 2001 | 10:10 AM
92zeddar's Avatar
I looked at mortec aswell and couldn't find anything..hmmm
he is saying it came out of a 87 IROC so it must be a roller engine right?
Dynomax cat back
Ram air
Old Oct 24, 2001 | 10:42 AM
Changa2's Avatar
You say 1457 3638. I don't see numbers beyond the 1410's. Highly unlikely but for what it's worth I did find 1409 3638 which is described as: 87-92, 350 CID, 2 or 4 Bolt,
Roller or Flat Tappet, 1-piece rear main seal.
http://www.racer-x.f2s.com/proc/engids.htm#blocks
Old Oct 25, 2001 | 09:12 PM
tacoboy's Avatar
either way it will work dude, your other parts of your car could care less whether you have flat tappet or roller lifters lifitn your rockers....
Old Oct 26, 2001 | 08:33 AM
92zeddar's Avatar
thanks guys!!
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
