Lifter or Rocker?????
Old Sep 11, 2005 | 10:28 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
I got a really bad lifter or rocker tapping I know it's on the drivers side other than that I cant tell what it its. I had a problem recently when the teeth on my timing gear rounded off causing improper valve timing. Could I have hurt something cranking with the valve timing wrong? It runs awesome I mean absolutely awesome but the tapping is horrid at anything other than cruse speeds with the radio on. I also went from 10w30 to 5w30 synthetic could the lesser weight done it?
EDIT: I Just changed my oil back to 10w30 and problem is still there and did not quiet it any.
Old Sep 11, 2005 | 10:31 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Piston could have smacked a valve when timing went off and bent a pushrod or something but its probably just a lifter crapped out on you.
tyeo098
Nov 30, 2015 06:27 PM
skinny z
Oct 5, 2015 06:23 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Stryker412
Sep 7, 2015 09:11 AM
