question about compression
Old Oct 27, 2001 | 06:32 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Are Compression ratio's and compression guage readings directly related?
I ask this because, when I had my 305 and put 350 heads on it, my compression went from ~145psi to about 120psi. the stock 305's came with 8.5:1? so I figured I lowered it to about 8:1 based on my guage readings. Then I put in my newly rebuilt 350. the engine shop said it has 9.4:1 compression. But when I tested them with my guage they all showed 135psi. So this confused me. I was expecting 150-160psi based on what my 305 showed.
A friend of mine just put in a used 350 into his truck, we tested the compression to find he has 150-170psi, a completely stock TBI 350, all carbon buildup removed..
so is there a difference between compression ratio and compression found with a guage?
My 350 in the camaro was bored .020, would this cause a lower compression since there is now more space in the cylinder?
Old Oct 27, 2001 | 07:00 PM
84zeddd's Avatar
A camshaft with alot of overlap will lose
some cylinder pressure because the exhaust
valve stays open longer allowing some of the
intake charge to escape.
Old Oct 27, 2001 | 11:45 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
ah yes, that makes sense.
Was I correct when I assumed that compression readings on the guage will raise when CR is raised?
Old Oct 28, 2001 | 12:07 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Compression ratio is the ratio the cylinder is compressed. It has nothing to do with psi. When the piston is at TDC the area above the piston is equal to 1. When the piston is at BDC the area above the piston is divided by the area at TDC. If this number is 8 times larger than at TDC then the compression ratio is 8:1. Higher compression ratios require higher octane fuels to keep the fuel from self igniting while under pressure.
Cylinder compression depends on things like valve and piston ring sealing, cam profile etc. It is how much pressure that is built up in the cylinder at TDC. A typical engine should be around 150 psi regardless of engine size. Anything under 100 psi is a very worn out engine. Higher pressures just mean less gasses are escaping promoting better burning of the air fuel mixture. Lower pressures usually mean something is worn out.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Oct 28, 2001 | 01:05 AM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
</font>
That was very helpful. Thanks
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
