Question about small base circle cam & 383
Old Sep 12, 2005 | 12:44 PM
spedrace35's Avatar
Car: 91 camaro z28
Engine: 6.3L, heads, headers, cam,.....
Transmission: 700-R4 w/shift kit and 3-4 WOT kit
Axle/Gears: 4.11
Ok you guys I need your help yet again,
Ok so I am the guy that is having the problem with the 383 build. I am using 6” rods and I am concerned about the clearance between the rod and the cam. I wrote to summit and asked their tech guys about this question. Now I know if I use a small base circle cam that I will have more clearance between the rod and cam, that’s a good thing! But the guy from summit wrote me back and told me that I can only use the small base circle cam with a carbonated engine. So do you guys know if this is true and why that is? And if it is true what are my options, I want to keep the 383 and the fuel injected system, I just need to get the right cam. If you’re wondering what cam I have been looking at it is as follows: (This cam is not a small base circle, it is just the geometry of a cam that I would like to get or something similar to it, and I do not mind going with another company):
Comp Cams 08-430-8
Operating range: 2000 – 5000 rpm
Advertised Duration: 280 in/ 280 ex
Duration @ .050: 224 in/ 224 ex
Lift: .525 in / .525 ex
Lob 110*
I hope this is enough information for you guys. Thanks for helping me out once again.
Old Sep 12, 2005 | 12:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A smaller base circle cam will only function properly with the sparkling effervescence of a carbonated engine due to the mechanical action of the rising bubbles.
I don't know what he's talking about, the cam doesn't care what kind of induction system you have on top.
Make sure your 6" rods have cap screws too for as much clearance as possible.
Old Sep 12, 2005 | 12:56 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
Thanks for your feed back. One question that I do have is what do you mean by sparkling effervescence of a carbonated engine due to the mechanical action of the rising bubbles.
Old Sep 12, 2005 | 01:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I thought there was a smiley that was doubled over laughing so hard, but I guess not. that was hilarious....
it's not carbonated, that's what your pepsi is, with bubbles eh? you are talking about a carbureted engine.
one question that came to me was, cap screws? a cap screw is a BOLT correct? what would normally be there? (or do you mean, don't use studs?)
ede's Avatar
ede
damn now i need to clean my monitor, this is too funny to lock
Old Sep 12, 2005 | 01:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
On a stock rod, the cap is retained by a bolt inserted through from the piston side, with a nut on the cap side. Usually when there are clearance problems between the rod and the cam it's actually the head of the bolt that hits the cam lobe. When using cap screws, the rods are threaded so that no nut is needed and bolts are screwed in from the cap side, so that there's no bolt head protruding on the piston side to interfere with the cam.
Old Sep 12, 2005 | 01:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
oh! so you take away the press fit bolt in the rod (I recently disassembled a 350 here, so I can picture that..), and tap the holes and but a different bolt in from the other side eh?
hmm, any other complicated machine work involved in that, or special parts? or just grade 8 bolts and a tap?
Sounds like a nice way to upgrade your SBC rods bolts (apparently a weak point?) cheaply...
Old Sep 12, 2005 | 01:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Rod bolts are a few grades beyond Grade 8. I don't know if it would be worth modifying stock rods. In his case, if he's using a 6" rod, then it's not a stock rod to begin with, so he could just get rods already set up with cap screws.
Old Sep 12, 2005 | 02:01 PM
Sonix's Avatar
Car: 1982 Trans-Am
well, a tap is cheap, so tapping the holes should be pretty cheap...
grade 8 is 150k psi tensile... (going by mcmaster carr here...), and socket capscrews are 180k psi.... so socket capscrews should be good....
new rods are like $400+.... Just thought it'd be cheaper to mod the rods and use those socket capscrews compared to buying new rod bolts from ARP for $100 and needing someone to press fit them in for me...
then again i'd need the rods resized either way..
Old Sep 12, 2005 | 02:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
When a rod fails, it will destroy everything inside your engine. Is it worth trying to save a few bucks?
Old Sep 12, 2005 | 03:02 PM
ede's Avatar
ede
damn this keeps getting better and better. i want to know how the DIY cap screw rods work out. my guess is great for something less than 30 minutes.
Old Sep 12, 2005 | 03:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'd be surprised if they lasted 30 seconds.
Old Sep 12, 2005 | 03:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
LOL... ok yea, that was just being cheap, sounded like a good idea at the time.... I realize that with a rod, when the cap has to be concentric, and precise to a fraction of a thou, then hand tapping *may* not be quite accurate enough....
Fine ! press fit freakin' ARP rod bolts for me.... stupid $100 for 16 bolts....
Old Sep 12, 2005 | 03:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Compare it with the cost of just one failed rod bolt and it looks cheap.
Old Sep 12, 2005 | 04:04 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Cap screw rods don't cost $400. I have seen Scat I-beams with cap screws running $200-250.
Infact rods are so cheap now, rebuilding, reworking, or using stock rods makes no sense anymore.
Old Sep 12, 2005 | 04:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
well sure, $250 US, plus exorbidant shipping, border chargers, then into canadian funds.... Hence my $400 guess, based on ~$250 for you.
I thought re-sizing rods was in the range of $100 or so... well, i'll find that out soon enough...
Old Sep 12, 2005 | 04:16 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Buy them on ebay to lessen charges.
Old Sep 12, 2005 | 04:27 PM
jimmy_mac's Avatar
lol, this is why everytime I see someone telling someone else on the board to call the guys at technical support to get help I have to chuckle a little. I rarely hear of these guys at summit or jegs actually knowing what they are talking about.
To make you feel better, my brother has been running a small base cam from comp cams for a couple of years now in his factory cast iron block with no effervesense issues from the carbonation. And he is not easy on this motor at all. I'm assuming the concern is with the strength of a small base circle cam. I would think a grind from comp cams even on a smaller base would be strong enough to handle any stresses thrown at it considering the materials they use.
Old Sep 12, 2005 | 04:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What are you complaining about shipping for? You're living in a city with how many speed shops?
Old Sep 12, 2005 | 04:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
haha, yea, you miss it yet? So far i'm using canadian tire (driverfx.ca ) and their selection is pretty brutal, and their knowhow is awful, but they're open late.. I'd rather not have to take a day off to go and buy something from a speedshop that's open 9-5 M-F....
oh, that reminds me, thanks for the tip on D&W, they sound like a really good shop, and i'll probably be going with them... (ps, they said they do deliver/pickup for blocks etc, but right now their trunk broke down.... uhh, bad omen?)
I'll have to make some calls later, upon closer inspection at ebay, some scat 6" rods (and therefore probably 5.7") with ARP wave lok bolts, ~$165 US, say $270 canadian, at the max. If I paid $140 for the bolts here, then $100 to resize, I'd save $30, by using old factory rods rather then brand new 4340 ones....
k, point well made Leigh.
Old Sep 12, 2005 | 05:05 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Hell no, Calgary sucks. And they have this new thing now every week, it's called Saturday.
Old Sep 12, 2005 | 05:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
I'll head over to MOPAC on saturday then
I think i'll end up getting most of my lower engine internals from the shop that does my machine work... let them double check that i'm buying the right stuff, since it's most crucial...
C-tire and it's wonderful cheap-ness and convenience will be left to accessories
Old Sep 12, 2005 | 05:59 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
Hey guys,
Well I just came back to this post to see if any more new info was posted. And now I feel like a dumb a** for not spelling carbureted correctly. So let me get this straight, if I use the small base circle cam I can still use my fuel injected induction system. This is the response that the guy from summit told me:
Response (A.C.) - 09/12/2005 02:20 PM
The cam selected is not designed to be used with fuel injection. The lobe separation is too wide. Cam selection is based on installation, whether or not a computer is being used, and vehicle use. The only rod that will clear the cam with no problem is the stock 400 Chevy rod which is a 5.565" length. The 350 block was never originally designed to be used with a 3.75" stroke so clearances must be made as necessary. The oil pan rail of the block must be machined and rod to piston clearance checked. This is required with any rod longer than the 5.565" unit. The rod must be clearanced or a small base circle cam used to stop the rod from hitting the camshaft.
This is the reason that I am so confused about why I can’t use a small base circle cam. O and I wish I know about cap screw connecting rods a couple of months ago. The balanced rotating assembly that I bought from Eagle Specialty Products did not come with cap screw connecting rods putting me in a bad situation. Let me know what you guys think.
O and one last thing, the guy from summit said that the lobe was too wide (the cam I was looking at had a lobe separation of 110*). If it is too wide then what lobe separation should I be looking for in a fuel injected motor.
Old Sep 12, 2005 | 06:04 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
OK sorry you guys one more thing,
This what the very first response I got from the guy at summit
Response (A.C.) - 09/12/2005 08:39 AM
You will have to contact our Sales department at 1-800-230-3030 with the part number of the cam. Sales, in turn, will contact Comp Cams to have a part number assigned to it with a small base circle. This is also assuming the vehicle will not be fuel injected.
This is one of the main reasons that I posted my question to begin with. Let me know what you guys think
Old Sep 12, 2005 | 06:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok, he's saying that it's not for a carbureted application because of the LSA, not because it would be ground on a small base circle.
Too tight of an LSA will bleed off too much cylinder pressure at idle and make the stock computer unhappy.
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
FYI Sonix, canadiantire orders from ekeystone.com which has a hella lot more stuff and a bit cheaper than driverfx.ca even though they are both the same company...
Old Sep 12, 2005 | 06:35 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
What would be a good LSA for my application. Street & strip. Will see the strip only a couple times a year. I do plan to get the computer worked on.
Old Sep 12, 2005 | 06:38 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What cam are we talking about here? The base circle size doesn't matter. It sounds like you are wanting to use the wrong cam for your FI application. You need one more appropriate for FI, with a larger LSA and less overlap.
Old Sep 12, 2005 | 06:43 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
what LSA and overlap would you guys recomend that I use for my fuel injected egine.
Old Sep 12, 2005 | 06:47 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
would you guys like to give a list of everything that i have gotten for this engine so far. Would that make it easier for you gusy to give me a more clear cut answer.
Old Sep 12, 2005 | 07:28 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
would be nice to know where your powers at and if your running an auto what stall.
Get me some specs on the engine and i can punch them into dd2000 and i can get you some numbers of approx what youll be putting out at the flywheel.
Old Sep 12, 2005 | 08:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
geez, go out for dinner and the thread gets huge...
ekeystone.com eh? I asked about special orders at c-tire and they told me that "oh, yea, keystone..." he told me I couldn't find out what keystone has, that's just for them, but to use driverfx.ca since it's virtually the same... (the prices are usually within 5% difference...)
driverfx.ca charges bigtime on shipping, I just use it to find the p/n, then go in to cantire and get them to order it. No shipping charges as they just get it in their normal shipping...
EDIT: also, if you were to look under say, exhaust, then to fit your car, selection is awful. just either look under brands (also bad), or easier, go to the website of your brand, ie. compcams, then find the part #, then search on keystone to see if they have it, and price, then go in to c-tire to get them to order it. bit of a hassle, but cheap.
-> also, looks like ekeystone is just for distributors... only businesses can sign up.... have you successfully used them?
speed: yea, a list couldn't hurt, we (and by that I don't mean me...) could tell you if you already bought something wrong...
mainly, are you running a stock computer and chip? speed density injection? if so, you must have a relatively stock type of cam to not upset it, or get used to burning proms....
larger LSA (ie 114* ish) will be ok with a stock computer, and anything with a powerband rating in the range of below 5500RPM would probably work ok.... (don't take this as gospel, i'm no FI expert...) but IMHO you should start burning proms, then nothing is holding you back from whatever cam you need.
and finally, looks like you now have the choice of getting a small base circle cam (is that significantly more expensive? and block work...) to avoid your rods, or different rods, which would allow you to sell your current rods.... (ps, I may be in the market for rods
Old Sep 12, 2005 | 09:58 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
Ok here is the list.
383 Fully Balanced rotating assembly from Eagle specialty products
stroke 3.75 x bore 4.060
6” rods (non cap screw)
Cam – yet to be determined as well as push rods
Heads – Pro Topline Pro lightning heads with 74 cc chambers
200 cc intake runners that have been polished
2.02 Manley intake valves
1.60 Manley exhaust valves
Comp cams springs retainers all the good stuff
Set pressure 130# open @ .50 lift 350#
Complete 1:6 Roller rockers
Heads were put together at a performance shot in my home town
Intake for the time being Ill be using the stock tpi system but Ill upgrade shortly to the TPIS Mini Ram
Headers- SLP 1 ľ” coated
Ignition – Stock but will up grade shortly
Torque Converter – I have hard many things about going to a high stall, I heard it will kill my gas mileage a lot. If I do get a new stall I want to keep it fairly low
Trans – 700-r4 with shift kit
Rear end 4:11
Computer - its stock, when I bought the car it already had a chip. I am planing on getting the chip reporgramed or I will get a new chip if it is not reprogramable. I would like to wait till my car is running and take it to the dyno and have it tuned there.
That is all that I can think of right now.
Remember that my intentions are for street use mostly and little strip use, probably only a couple times a year.
And I do not plan on having a screaming high RPM motor, that is the reason why I wanted to go with a stroker. I would like to have my power from low to mid RPM’s , I don’t want to go above 5,500 RPM and the most I would want to push my engine is 6000 RPM.
I hope that this helps sorry that it took me so long to write back I had leave the house for a wile.
Old Sep 12, 2005 | 10:06 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
When I built my stroker, my rods were hitting the cam. I choose not to grind my rod bolts since I paid $250 to get everything balanced. I just returned the cam and got a small base circle cam and it wont hit (it will hit still, but if it is timed (timing chain) it wont). Holy parenthesis.
Old Sep 12, 2005 | 10:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's a lesson in there on the value of trial-fitting the assembly before balancing.
Old Sep 12, 2005 | 10:21 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
WhiteHalk,
I know what you mean I dont want to grind mine because of the same reason. For your timing how do you have it timed, do you have the intake valves opening a little before top dead center or right at top dead center. If your timing in not right at top dead center can you tell me how many degrees before or after your vlaves are opening from top dead center. And by how far are the rods going to miss the cam? And are your rods in your 383 6"? Thanks for you input
Old Sep 12, 2005 | 10:35 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
Sonix,
Hey thanks for your imput, I really dont know about prices for the small base cam or if it requires any modifications does anyone here know that answer? I dont know if I am going to be selling the rods, if I get new rods then I have to rebalence the whole thing and to get the rods I want from Eagle its going to cost me a couple hundred more bucks!! I still dont know what I am going t be doing. First I just want to find out the cam that I want to run then find the prices and if there is any additional work required on my block. But if something turns up I will let you know. Thanks for your imput
Old Sep 12, 2005 | 11:04 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Sorry to thread jack but if you want a little bit more parts to look at go to
www.ekeystone.com
user: 88923
pass: tires
it was an account set up to check pricing so dont bother trying to actually order stuff because it wont work. The pricing is what your local CT "should" charge but the end price is up to them.
Ahhh the joys of being a partsman... lol
Old Sep 13, 2005 | 09:09 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Originally posted by spedrace35
WhiteHalk,
What I meant by timing it correctly was, that I set the crank so that the rods would hit a normal cam. I then installed the small base circle and rotated it. It still hit, and I got nervous. Then I installed the timing chain and lined up the dots. The cam did not hit. To accurately measure where the cam is I would have to install a degree wheel and get the actual degrees. Timing gears have been known to be off, as my teacher checked his and it was 10 degrees off!!!! I guess it would be trial and error if the cam still hits you may have to jump a tooth or try another timing chain. I am about to upgrade to a larger lift cam...I am scared.
Old Sep 13, 2005 | 09:11 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Thank you for reminding me although I fully understood my mistake and won't every build a stroker without clearancing first.
Old Sep 13, 2005 | 09:16 PM
spedrace35's Avatar
Car: 91 camaro z28
Axle/Gears: 4.11
I learned my lesson about building a stroker also!!!!!
Old Sep 13, 2005 | 10:27 PM
  #42
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
These kinds of things aren't unique to strokers. Surprises can be expected any time non-stock parts are used.
Frozer!!!
Jan 19, 2024 04:55 PM
junkcltr
Aug 2, 2019 11:12 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
