Counter Weight Cranks...Why Not?
Old Oct 28, 2001 | 01:43 PM
gruveb's Avatar
Car: 1989 IROC-1
OK..Here is a question that I have been pondering for some time now.
Why aren't there Counter weight cranks for our SBC's? If there are, I guess I just don't know about them. If I don't know about them, it is probably because they are much more expensive and not common.
The idea behind counterweight cranks is great. Really helps smooth out the rotating assembly. An engine that is properly blue printed, balanced and running a counter weight crank is really smooth.
So why don't we have them?
http://www.gruveb.com/z28
Old Oct 29, 2001 | 12:54 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
If you are looking for an internally balanced rotating assembly yes, you can find these. Worst case I know Lunati has a set...probably close to $4000 or so though If you are looking for a crank that is counterbalanced so that it can idle at ~200 RPM and "sound mean" I am not sure if these are available. These usually involve a higher, unbalanced rotating assembly and drop Torque/HP, so IMO it is undesirable.
Corry
Old Oct 29, 2001 | 01:14 PM
gruveb's Avatar
Car: 1989 IROC-1
Corry,
Well it just appears to me that not very many people who build these engines preach some of the details that are preached in some of the other circles.
Counterweight cranks don't really allow you to idle at any lower speed (from what I understand...I've had an engine with a counterweight crank), what it does is kind of act like an additional harmonic balancer. By being counter weight it spins more easily, with less friction, and is another way to allow your red line to go up.....basically.
As far as learning about engine building and so on, I "grew up" learning about type 1 volkswagens...bugs.
Now the displacement in those are very small, and the redlines are relatively low for a small engine, actually very similar to many SBC's.
But building those engines was much more detail orientated.
For example, each cylinder was checked individually for the actually displacement. There are small variances between each. Light machine work is made to each piston to get all of the cylinders volume as close to identical as possible.
So I was just curious why nobody made counter weight cranks....
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
Damon
Sep 26, 2015 04:29 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
roysatikas
Sep 7, 2015 08:08 PM
