oil seeping between head and block deck
i built sbc stroker 383 this summer and after running for several months i notice oil is leaking between the aluminum head and the cast iron block deck. the heads are 23deg trick flows c/w felpro 1010 gaskets. the heads where torqued in three stages to final torque spec as per the head manufacture, i have since check the torque recently and everthing is still to spec. i have no oil in the coolant or antifreeze leaking between the block and head. i have no idea what is causing this, it is more pronounced on the drivers side by #7 and #1, on the pass side it is more by #8. plugs are all dry, no oil in the combustion chambers. oil consumtion is minimal. block is original deck height. any thoughts gents.
Car: yep
Engine: uhuh
Transmission: sure does
I usually use a little rtv on the deck surface and the head surface right where the intake valley is on the head gasket.
This seems to keep the oil from leaking there.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Transmission: 4L80E/4L80E
I think Engineboy has it. There is no pressurized oil passage going between the block and the head. You're probably seeing the drop-off point from a higher leak - the intake/block/head corner Engineboy describes.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ4 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (ported World 305 heads, Crane PowerMax cam, Hooker 2055 headers, 3" Catco cat & 3" catback w/Flowmaster, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
oh!contrare.....there is a pressureized oil passage located on the block on the outside of the number 7 piston.it is contained by a stamped steel plug if that plug is cracked or warped it would leak.it sounds like that isn't the problem cause you would definately have a consumption problem.
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
best e/t:
ambainb
Apr 25, 2016 09:21 PM
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
rithsleeper
Aug 11, 2015 07:55 AM
