Oil Change question....
Old Oct 29, 2001 | 07:23 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
My car has had the same kind of oil used for every oil change that it has had.... I believe that it has had Castrol. (155k mi.)
I usually use Valvoline Durablend....
Would it hurt/help to change oils now?
Any suggestions?
http://kiztope.50megs.com
92 Pontiac Firebird Formula 5.7/A4
K&N, nothing else yet!
92 Rs 3.1/T-5
Beautiful car, several mods, but now I am turning attention to the 'bird!
AIM : Theonekiztope
ICQ: 8787542
"Maybe one day life will take a turn. When it does Lean into it!" Leon Calrinsky (98)
Old Oct 29, 2001 | 07:38 PM
JETHROIROC's Avatar
Won't have anything to do with anything. If you stick with dino oils, they're all essentially the same so just pour in what you want. If you like Valvoline then run it.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Oct 29, 2001 | 07:45 PM
breathment's Avatar
ya, just make sure the castrol isn't blend or full synthetic, cause unlike plain dino oils, mixing synthetics can be bad.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
eightsixseven
Dec 16, 2024 01:50 PM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
