85 v8 alt vs 88 v6 alt?
Old Sep 15, 2005 | 06:17 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Well, I have my 120amp alt that I ran on my 2.8, I wanted to keep it since i did pay for it and it is 120amp. But it seems I will have to custom make a dang bracket. I've tried multiple brackets, but nothing works. SO, should I get an alt for an 85 v8, or can I swap my alt guts into a diff case or what? Also, whats the diff between a 1 wire and the others? My current alt had a pig tail with 3-4 wires (i dont have pigtail anymore, and it's been a long while since i've seen it)
I found this on summit
http://store.summitracing.com/partde...=KeywordSearch
In my price range
thanks
Old Sep 15, 2005 | 07:39 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
http://purplesagetradingpost.com/sum...o/onewire.html
Old Sep 16, 2005 | 09:29 AM
Car: 88 Camaro
Engine: 310 LG4
thanks for the link. Man, that is not cool. My problem is getting an alt that will work with my bracket and my under drive pulleys AND I need to find a pigtail for it.
Old Sep 16, 2005 | 09:59 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
The underdrive pulley should work on any alt that fits your bracketry. The stock 85 V8 alt uses a flat connector with two terminals to plug into the alt, one wire goes to a bolt terminal on the back, the other goes to the volt meter in the cluster. Another wire comes out of the bolt terminal and goes to the battery.
I was lucky enough to find a brand new one of those at the scrappers. Was even more lucky to find a 9 bolt rear end in the same car. Wasn't so lucky dragging the damn thing out of there myself.
BDR
Nov 7, 2015 03:05 PM
J.C. Denton
Sep 21, 2015 04:23 PM
Slush92RS
Sep 2, 2015 08:56 PM
KlayBuRn
Car Audio
May 15, 2001 02:20 PM
Mkos1980
Sep 20, 2000 10:00 PM
