8-AN line = ......inches?
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
How wide is 8-AN line? I need to run 1/2" fuel lines if i am gonna run a Y to my N2O. If it is less than 1/2 I will run 2 seperate lines and 2 fuel pumps. Thanks for the help guys.
Engine: LS3
WOW thank you so much. I have no idea if that was a really stupid quesiton. But thanks again.
That info makes my life a ton easier.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
AN is an old term meaning Army/Navy but many people still use it. It's always based on sixteenths of an inch. AN20 would be 20/16 or 1-1/4"
A more modern term for AN fittings is JIC. Joint Industries Council
The AN/JIC fittings use a 37* flare.
