attn rb83l69 or anyone reg 356k rings
Old Oct 30, 2001 | 02:27 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i'm installing the rings on my pistons, the 2nd one has a angle grooved on it but the top and second groove rings have yellow markings on the side of them i'm just wondering if the yellow markings go on the same side? i see a dot on the top ring which means up, but the second ring, i'm not sure if the angled part goes up or down
Old Oct 30, 2001 | 03:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The angle is the "up" marking.
ICON Motorsports
Old Oct 30, 2001 | 04:28 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
wait rb, i found a dot on the second rings, that means up right? if so the angled part of the 2nd ring is facing down
Old Oct 30, 2001 | 04:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If there's a dot, yes, it is probably the top. There is a "hierarchy" of markings: dot first, then a chamfer if there's no dot, then last of all, paint. Paint is not usually used because you lose it when you wash the rings in solvent before assembly anyway.
IIRC the markings are covered in the destructions...
ICON Motorsports
Old Oct 30, 2001 | 05:37 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
thanx rb, there are no markings on the 2 oil rings, so those go in anyway correct?
Old Oct 30, 2001 | 05:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right... those have no defined top or bottom, they can go either way.
ICON Motorsports
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
