Need a recommendation on the spark plug gap with acel super coil.
Old Sep 17, 2005 | 09:52 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Am I right to say that for a stock coil .035 would be good but on an acel super coil HEI OEM replacement .045 would be more ideal?
Old Sep 17, 2005 | 09:54 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
You might get a trillion opinions on this. .045 should be fine. I'd be satisfied with anything between .035 - .045. Gap them so they are all the same.
Old Sep 17, 2005 | 08:03 PM
Damon's Avatar
.040-.045 would be just fine. Make sure you buy plugs that are designed for a gap that wide. Stock replacement plugs that are designed to work with a .035 gap won't work for a bigger gap- the electrode would no longer be anywhere close to parallel with the top of the center electrode- that's bad.
For a stock cast iron SBC cylinder head a good starting point for a plug that could take a wider gap look at an Autolite 24 (or equivalent from other manufacturers).
Old Sep 18, 2005 | 07:14 AM
Thanks Bill Nye! They are autolite, I cant remember the 20 something number. I didnt have a gap gauge at the time so I eyed it out and matched it to the best I could to the old plugs to just try and get the engine started after a long process. Yea I know, but I just wanted to hear it start after working on it for 3 weeks.
Old Sep 18, 2005 | 10:24 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
You'll see a bigger return on indexed plugs over a bigger gap... not that you'll see much with that either.
Old Sep 18, 2005 | 10:27 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yea, but indexing takes that much longer versus gapping....so if it's that little to begin with, why exert that much energy?
Old Sep 19, 2005 | 01:42 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
So what your saying here is that Autolite OE replacement plugs #26's that come pre-gaped .035 are supposed to be .035?
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
db057
Aug 22, 2015 08:17 PM
