Red hot headers...
Old Sep 24, 2005 | 10:15 PM
  #51
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
How much would you want for the system??? Would you be up for a partial trade with my carb/intake?
Im oppsoite of you, i cannot afford the bit more gas a carb uses compared to FI. With a new sled to pay for i need all the $$ i can get.
Old Sep 24, 2005 | 10:42 PM
  #52
ChevyRacer's Avatar
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
i understand, pm sent.
I am out for performance. YOur out for a car to drive.
Old Nov 3, 2005 | 10:12 PM
  #53
BlackBeast'88's Avatar
Car: '88 Formula
Engine: 355cid
I'm having a very similar problem. I had the SVO 24lb inj in the car and all of my header tubes were glowing. I had problems with timing and I think I got that fixed but someone was telling me that they thought my problem was way too much fuel and they thought the SVO inj were the problem. I switched injectors to only find out that the problem with my headers tubes glowing didn't go away. The car doesn't over heat at all and the performance is there but I have these glowing headers. Please tell me what you did to fix your problem.
Old Nov 5, 2005 | 03:18 PM
  #54
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
#24 injector with a 305 'puter?? Hmmmm.
Old Nov 5, 2005 | 03:46 PM
  #55
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
LOL My fiend put them on his 86 305 TPI and it wouldnt even run until a chip was burned.
Old Nov 5, 2005 | 08:50 PM
  #56
Car: '88 Formula
Engine: 355cid
There isn't such a thing as 305 puter. It's either a MAF or SD ECM. The bin I'm using is from a 89vette.
Old Nov 5, 2005 | 08:53 PM
  #57
Rob Wade's Avatar
I'm meaning 305 'puter containing a 305 chip.
Old Nov 7, 2005 | 10:34 PM
  #58
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
305's came in both MAF and SD.
tommy z-28
Oct 6, 2015 10:58 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
TheExaminer
Sep 28, 2015 02:28 PM
corey8084
Sep 17, 2015 02:56 PM
86IROC112
Sep 11, 2015 04:04 PM
