A Big Thanks To All That helped me- An Update on Smog removal
Old Oct 30, 2001 | 09:08 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Thanks to all you guys that helped me with advice on removing the stripped out bolt on my smog pump.
(What a bitch)! I chiseled, and used the dremel, and lubed, and chiseled some more! Finally I cut a slot in it and turned it out with a flathead screwdriver. I damaged the bracket a little bit, but I don't plan on putting the smog pump back on. Even if I do put the pump back on, it will still work. I didn't damage it that bad. I removed all the smog mess, and installed brass plugs into the exhaust manifolds. While doing this, I found the passenger side manifold had two loose bolts so I re-torqued them. It looks so much less cluttered under the hood now. All I have left to do is put my new belt on tomorrow and fire her up. Hopefully I will have no problems. Thanks again for all the advice!
later
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
onefreakz
May 14, 2018 12:15 PM
jackhammer
Aug 15, 2015 10:04 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
