rebuild kit
Old Sep 18, 2005 | 03:16 PM
duffgun's Avatar
Car: ford Mondeo
Engine: 2,500cc V6
rebuild kit
ok once i get my new camaro which will proberly be a 305ci i am going to rebuild the engine now is this Federal Mogul Engine Rebuild Kit any good http://store.summitracing.com/defaul...+-59098+-42272
thanks
Old Sep 18, 2005 | 03:26 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Check out that rear restrictor port issue. Some intake manifold gaskets have them open, some closed. I guess it depends on which intake manifold you use but the fel pro HS gaskets on mine came with the closed off rear restrictor port. It may be the reason that my temp sensor is not touching any water to turn the fan on at 190degrees.. fun, that means take the intake manifold off again.
Old Sep 18, 2005 | 04:06 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Does the engine for sure need a rebuild?
Old Sep 18, 2005 | 04:08 PM
duffgun's Avatar
Car: ford Mondeo
Engine: 2,500cc V6
sorry link didnt work the part number for the kit is FEM-MHP124-311
Old Sep 18, 2005 | 04:13 PM
duffgun's Avatar
Car: ford Mondeo
Engine: 2,500cc V6
well the car im gona have a look at next week has got 140,000miles on the clock its a 1984 305ci, thought it might be worth a rebuild, i dont know if the intake gaskets on that kit our open or close.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tonys91rs
Oct 10, 2015 03:31 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
