Crack in plastic part in gas tank...Problem?
Old Sep 19, 2005 | 12:20 PM
92CamaroLS1's Avatar
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
Will the crack in the plastic part shown in the pictures cause any problems? I was reading up on 4th gens and the plastic bucket they have that creates a Venturi effect always making fuel available even when the tank is very low. Does this plastic part do the same in our tanks? Will the cracks cause any problems? I cant see fixing it without buying a new tank. I personally dont think it will cause a problem, but before I put it all back together I want to make sure. Here are the pics. Thanks.
Chris
Old Sep 20, 2005 | 01:54 PM
Anyone???
Old Sep 20, 2005 | 02:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Other than the obvious, like a piece of it breaking off, I can't see a problem with it.
Even if a piece does break off, I'd hope the sock on the end of the pump would stop it.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
arod231
Aug 16, 2015 02:51 PM
kyleb24
Aug 15, 2015 08:24 AM
1nastygta
Aug 8, 2015 07:38 PM
