Weird rattleing at low rpm's
Old Sep 20, 2005 | 12:32 AM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Axle/Gears: 4th gen 3.42 posi
Well I just put on a double-roller timing chain with some helpful replies from this site. For a while now at low rpm's I would hear a weird rattleing sound. I thought it was just my timing chain. The weird rattleing sound is still there.
I did check the FAQ page but the transmission problem says,"especially while in reverse." In reverse I'm fine, it's only when I take off under normal conditions. Could it be that I need that update for my tranny or something else? Any suggestion?
Old Sep 20, 2005 | 06:57 PM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
sounds like exhaust by what your describing. If you know where your cat is you can hit it with a hammer and see if you hear the noise there are ceramic bricks inside that tend to break loose when it gets old. If so you need a new converter.
Old Sep 20, 2005 | 11:34 PM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Well I did replace it earlier this year and I bought a cheapo from Autozone. I hear they only last a year, if you're lucky. If I break out the that stuff that is inside will it stress out any parts like my O2 sensor or my smog pump? Just wondering because the cat has a return pipe.
Old Sep 21, 2005 | 12:48 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
That's actually a feed pipe going into the cats from the AIR pump. Nothing flows out of the cat thru there.
Old Sep 21, 2005 | 10:38 PM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Peach!
Old Sep 22, 2005 | 02:02 PM
michael's Avatar
Car: 1991 Formula
so what was the rattle?
Old Sep 24, 2005 | 01:09 AM
ta3ff's Avatar
Car: '89 Camaro RS
Engine: none
Transmission: none
Hopefully I'll have time to check out the cat tomorrow. With work and retro fitting a '61 chevy pick-up(not mine), I've been neglecting my camaro.
jklein337
Sep 19, 2018 06:23 PM
87iroctheo
Dec 4, 2016 11:47 AM
xxx3man`
Sep 23, 2015 10:37 PM
Jake_92RS
Aug 17, 2015 09:42 AM
mustangman65_79
Aug 8, 2015 12:07 PM
