edelbrock rpm air gap intake accessory holes
Old Sep 20, 2005 | 11:27 AM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
hey i was wondering if anyone knew what i needed and what size to fit for the holes in the intake.
im hoping the front ones are 1/2" i have a pipe plug for one side of the thermostat, and what is it called for the other side, hose barb? i need it for my heater hose.
and what about in the back?
Old Sep 20, 2005 | 11:45 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Unless you need to thread sensors in them or something, plug the holes into the coolant ports at 3 corners and put a hose barb into the other one.
Old Sep 20, 2005 | 02:09 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok so just a hose barb for the front heater hose, and plug every other holes.
thanks.
Old Sep 26, 2005 | 11:13 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
anyone know what size i need for pipe plugs on this intake?
the front 2 on each side of the thermostat 1/2" pip plugs fit perfect, what about the back 2 on each, and the one up to behind the carburetor, 1/2" seems to be too big.
Old Sep 27, 2005 | 03:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The vacuum port behind the carb is probably 3/8 NPT, the coolant parts at the rear should also be 1/2 NPT.
Old Sep 27, 2005 | 06:49 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
see there are different measurements.
the front 2 are 1/2" pipe plugs.
the 1/2" pipe plugs are too big, and 3/8" are too small.
Old Sep 27, 2005 | 08:02 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
The plugs in the rear are 3/8 pipe.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
