timing wont stay put, really need help
Old Sep 26, 2005 | 07:31 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
alright im about ready to take some 12 gauge buckshot to my distributor this is so frustrated. i have to set my timing literally every day. the dist clamp bolt is really tight, im afraid i'll strip it if i do it any tighter. but i can still grab the distributor and turn it either way without much trouble. its insane. is that little clamp really the only thing that holds it in place? i've got an msd distributor, the clamp only is about 1 inch wide where it contacts the flared out part of the distributor that sits on the block. is this the way its supposed to be? please help, im almost ready to have my neighbor weld the #$@*ing thing on.
Old Sep 26, 2005 | 07:55 PM
89 CamaroIROCZ's Avatar
Try a new distributer hold down? Its usually a little bent so it can keep pressure on the distributer, if you tighten it too much i'd imagine it can flatten out and not keep a good hold on it. There really isn't anything else it might be that could be causeing your problems
Old Sep 26, 2005 | 08:20 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Did you possibly put the holdown on upside down? It is bent a bit and if its upside down it will make very little contact with the dizzy.
Old Sep 26, 2005 | 08:28 PM
1meanGTA's Avatar
its a possibility, i started having these problems after i replaced my distributor gear, so its a good possibility. ill go try flipping it now and see if it helps.
Old Sep 27, 2005 | 10:57 AM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
Do you have a stock style or a chrome hold down? Had no luck with chrome ones.
Old Sep 27, 2005 | 08:20 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
yeah if it's a chrome one you may want to rough up the bottom so it grabs the dizzy a little better.
Old Sep 27, 2005 | 08:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Maybe try a shorter bolt.
Old Sep 27, 2005 | 08:37 PM
Dialed_In's Avatar
does the dist. you bought have an adjustable collar?
Old Sep 27, 2005 | 08:45 PM
1meanGTA's Avatar
sure enough, the thing was upside down. doesnt move now, thanks a lot.
Ghettobird52
Jul 5, 2024 11:18 PM
bryan623
Mar 22, 2021 06:43 PM
ezobens
Aug 19, 2015 10:29 PM
novaderrik
Aug 10, 2015 12:44 PM
