Sqquuueeeekkkk
Old Oct 31, 2001 | 10:13 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Sqquuueeeekkkk
Today my car started squeeking when I pulled out if my parking spot and drove a bit, it stoped after a minute. It sounded lke it was coming from the rear when the widows were down and the front when they were up. The sound was like that when the brakes are bad and you hear the metal. My thought is that its a bearing going? any other thoughts? I was planning on driving it to PA(1000 MI away) in a couple weeks, but if the bearings about to go, probly shouldn't.
1 5/8 Hooker Competetion Headers, custom y-pipe,no cat, modified Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Nov 1, 2001 | 11:47 AM
Car: 92' RS
Engine: LO3
Can someone tell me how I would test for this at least? rather than just replacing them until the squeek goes away?
Old Nov 1, 2001 | 03:34 PM
82sportcoupe's Avatar
how cold is it where you live? if it stopped it could have been your speedometer cable, mine does it now and again if the car is cold. probably not the correct answer but its a suggestion. but dont listen to me. im still learning myself
Old Nov 1, 2001 | 05:27 PM
camaro6spd's Avatar
hey man, bearings are cheap and easy to replace. if you have a few weeks and it is them then just replace them, it takes all of a 1/2 day or so if you procrastinate(spelling)
