Small block Ford in a third gen??
Old Sep 21, 2005 | 01:12 AM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Ok here's the deal. I know this might sound sacraligious (sp?)
But I want to know what's involved with putting a SBF in my camaro. I've seen it done the other way around (SBC in a mustang), But right now I'm rebuilding my 5.0 in the form of a 347 stroker, forged internals, alum. trick flow heads, nice cam (.574" lift and that's all I'll tell) plus a nice breathing intake and TB etc...
My buddy "Wild Bill" devine estimates 440+HP at the crank when it's finished. Plus it will be balanced to withen .5gm, all the usual stuff align honed and bored, decked etc... Besides motor mounts (where can I get them??) Anything else I'll need? It's backed by an upgraded t-5. What size driveshaft, that kinda thing.
Got the 'burban to drive for now.
Thanks.
Old Sep 21, 2005 | 05:20 AM
ede's Avatar
ede
after you get the engine and trans set in pull a tape and you ought to be able to figure out the DS length by the way the numbers are arranged on the tape. why would anyone with half a brain want to go to the time and expense of doing this?
Old Sep 21, 2005 | 05:29 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
your a blunt **** ede you know that.
now I know I might not always beat around the bush and instead take a few pokes at the bush instead, but man you just take that sledge and beat the hell out of the bush and I must add your aim is good cause I don't think I seen you miss the bush yet
and guys don't take this sexual as that is not how I mean it. what ede does on his own time with his own bushes is his own thing. I am talking the proverbial bush and not george bush either.
wow there is just too much bush around here.
and guys don't take that the wrong way either. you know what I mean
sad thing though is for how much bush there is around here there really isn't all that much.
now guys you CAN take that the wrong way as this forum there isn't that much bush
man I need some sleep
Old Sep 21, 2005 | 06:27 AM
ede's Avatar
ede
rx you need some sleep or i need more work on my reading compression skills.
maybe i should of expanded a bit more on what i said? do what you like but unless you get satisfaction from doing more to get less there are better ways to get 440+ HP at the crank
Old Sep 21, 2005 | 09:05 AM
WoostahGTA's Avatar
Car: 1990 Trans AM GTA
I have to agree, theres not much point in doing this. SBC parts are generally cheaper then SBF's, and why stroke a 302 when you can stroke a 350? Just about any junkyard will sell you a core 350 for ~$150 if you're in need of a block. I'm sure the swap would end up costing alot more then that. Also, ford blocks are inferior to chevy blocks in that they don't have nearly as much meat on them as they should, unless of course you use a ford racing block.
Old Sep 21, 2005 | 09:15 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Why would you want to go and do something like that?
If you do i would reccomend the sledge hammer route and while your at it remove all GM and camaro badges from the car and throw a match in the gas tank
Old Sep 21, 2005 | 10:08 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Is this going to to be MPFI or are you going to just pop a carb on it? Either way it's alot easyer to put a SBC into a fNord then vise versa. You can use the upper most part of the fNord engine mount and weld it to a GM clam shell. Dont know what one would do about the trans.
Old Sep 21, 2005 | 04:20 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
I've seen conversion kits to mount a th350 to a sbf, but why? I mean I like ford's. Friend has a mustang I love that car. I love my firebird, I love all fast cars minus the *** cans. But I believe it's in the bible, let fords have ford motors and GM have GM motors
Old Sep 21, 2005 | 04:37 PM
nidyanazo's Avatar
The mustang body is beat. The camaro is flawless.
That's why.
The car is about to break into the 12's, and with the new motor in it low 11's are going to be the norm. Always liked the looks of the third gen camaro more. IMO the mustang is the superior car for drag racing.
It just dosn't look as "pretty".
I just was asking a hypothetical question. I actually like the response form people when I beat them in a car that looks like it has 80hp max.
Nevermind you can close this thread.
Old Sep 21, 2005 | 04:44 PM
I agree, generally mustangs do better in a 1/4 while F bodies have a better top end. I'm not saying an f body can't do a good 1/4 mile but the fox bodies tend to be lighter and that 5.0 is a good motor. When I was building my mustang. I used to get in arguments with people who'd always **** on f bodies. Its all how you define fast. Fast can be a good 1/4 mile time or fast can be a stock 4th Gen that hits nearly 165
Old Sep 22, 2005 | 08:45 AM
WoostahGTA's Avatar
Have you considered buying a 4 banger mustang and doing a drivetrain swap? You have all the parts after all, and i personally like the looks of the 87-93 mustangs, especially in hatchback trim and with gt or saleen ground effects.
This is how i think of it, mopar blocks belong in mopars, ford blocks belong in fords, and gm blocks go wherever you damn well please.
Old Sep 22, 2005 | 03:04 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
blasphemy.
i second the cheap-o stang swap. find a 4 banger lx, those things are light as hell.
Old Sep 22, 2005 | 05:32 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Blasphemy! You should be boiled in oil and flogged for even thinking of such a thing.
Old Sep 22, 2005 | 06:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a word for those who deliberatly subject themselves to pain.
Old Sep 22, 2005 | 06:23 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I'd have to agree, by the time that you cut, reweld, change just about everything. You could have bought you a better mustang with maybe a 4 cylinder and built a 320 HP 350 for the camaro(Hot Rod built put some stock 193s and a XE-268 into/onto a mid 70s Impala 350 and made 320 HP for $460.00 a few years ago, including the cost of the wrecking yard engine. I believe they re-ringed it and ran with it.(99 IIRC). Then they turned around and for less than $1K they made it into a 375 HP powerhouse. The previous two were with dual plane intakes and a stock Q-Jet. Then they put a holley and a single plane on it and made 400 HP.
Old Sep 22, 2005 | 07:57 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
Mustangs are lighter, that's why they make good 1/4 mile cars and a 302 based engine will be slower in a camaro. You'll still make good numbers and have a fast ride, like some of the stroked 305's out there.
I think it would even be possible to use a stock driveshaft if the output splines are the same. So long as you mount the transmission first, then do the motor mounts. The 4thgen fbodys used a ford T5 and I've read of people using the ford T5 for chevy applications so I know there is at least a good chance that you won't have to have a driveshaft made. If not call up Denny's DS or cut and weld your own like the circle track guys do around here. Headers would probably be more of a concern than D.S. anythings possible with a grinder and a welder.
Old Sep 22, 2005 | 08:06 PM
ND4SPD86's Avatar
Car: 87 Buick Regal T
Axle/Gears: 2.56 blah
I have a fox cougar in my back yard I thought of putting a stroked 305 in but instead I just bought a my 86 Trans am to drop the 305 in instead of trying to jam it into the cougar and I am sure I save a s#$* load of money, time and a few headaches in doing so. I would just buy a lx 'stang and go from there
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
