no fuel problem
Old Nov 1, 2001 | 10:23 PM
JunkHead84's Avatar
no fuel problem
the car starts fine if i pour gas in the carb. i ran an edelbrock mechanical pump first but it wasnt sucking gas. Then i found out there was no lobe for the push rod on my engine. so i ran a purolator universal electrical pump. i ran one wire to ground and the other to the coil, (i ran the red wire and plugged it into the distributor cap). i turn key i hear nothing, i try to start it it still doesnt start untill i put some gas in the carb. I had the fuel line in a gas can to see if it would suck because i didnt take the origional in tank pump out yet, i just disabled it. can somebody tell me what i did wrong?
Old Nov 1, 2001 | 11:08 PM
Vader's Avatar
Don't connect the pump power source to the coil source. Find a different source for the IGN circuit, like the fuse panel.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
