NEED HELP FAST, EASY QUESTION
I JUST TOOK MY 88 GTA TO A SHOP TO GET MY OIL CHANGED. I PROVIDED MY OWN OIL AND FILTER. I WAS SUSPICIOUS OF THE BUSINESS SO WHEN I WENT TO PICK UP MY CAR I SAID I WANT TO SEE THE EMPTY OIL BOTTLES. THERE WERE ONLY 4 QUARTS, I HAD BOUGHT 5. I KNOW DAMN WELL THAT IT TAKES 5 QUARTS SO I SAY WHERE THE HELL IS MY OTHER QUART. HE SAYS, OH I DONT KNOW, I PUT IN ALL 5 THOUGH. SO I CHECK OIL AND ITS A QUART LOW. HE SAYS, SOMETIMES THESE CARS TAKE 6 QUARTS, I'LL GO BUY YOU A NEW ONE AT THE SHOP NEXT DOOR. SO HE ADDS THE OTHER QUART AND ITS FINE. I KNOW DAMN WELL THAT CAR DOES NOT HOLD 6 QUARTS, CAN I PLEASE BE VERIFIED BEFORE I REPORT THE COMPANY?
Car: 99 Formula
Axle/Gears: 342
I always put 5 qts. in and I'm fine. I've heard of some people using 5.5 qts. I would suggest changing your own oil. If it's the fact that you have never done it then have some one show you, it's very easy, and I'm not mechanically inclined and can do it.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
The cars generally only hold 5 quarts, but I think you can get a bigger filter to up the capacity some.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
89 iroc-z 305 tbi
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
5 Quarts
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
I used to change oil at a lube station. Some of those guys get pretty lazy and don't do what they say. With a fram filter in my L98 five quarts always filled it. The Chiltons and Haynes manuals both say 5gts with filter if that helps
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
My L98 with all of my mods holds almost 6 quarts.... I always put it a hair over the full line though.... don't want to starve that M55HV.........
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1987 GTA L98 MD8
My GTA
Fast355
Dec 2, 2016 06:33 PM
