2 msd tech about distibutor
Old Oct 29, 2001 | 09:37 PM
ONEFORMULAOVERALL's Avatar
mods r in sig
i have a billit distributor part # 8366 from u and i seem 2 b burning up rotors and caps like the spark is 2 great and it is crossing over the terminals. coroding them white color. now i saw is summitt that u make a cap extension that puts the terminals further away i guess to stop this problem?
do u have any ideas or need more info?
thanks j.c hicks
92 F-BIRd FORMULA T-TOP (WHITEKNIGHT) 5.7L-98,700R4B&MSATURDAY NIGHT
SPECIALTRANS 2500STALL,54MM-AS&M TB-PORTPLENT,LARGETUBRUN,L-98 ALUM. HEADS PORTED CRANE AFPR.45PSI,SMOG PUMP GUTTED,
UNDER PULLEYS K&NCOLD AIR KIT,160THERMO,ELDB HEADERS W/3 1/2 Y PIPE 2 RINO CAT 2 DUMP
MSDDIST,6AL,TAYLOR WIRES
2BLASTERCOIL.ACCELL PLUGS
CUSTOM FASTCHIP BY ED WRIGHT,AUBERN POSI W/ RICHMOND 3.23 AND MOSER AXEL SPLINES CRYGO FROZEN,TUBE FRAME CONNEC,EIBACH PRO.,HOK.LOWER ARMS,PAN,TQ ARM,ALUM. DRV.SHAFT.
PST KIT.1LE BRAKE KIT CROSSED DRILLED ROTORS MANY MORE MODS FORESEEN IN MY ERA!13.38ET @ 107.75MPH
Old Oct 30, 2001 | 03:29 PM
ttt
Old Oct 31, 2001 | 06:36 PM
9.0L Firebird's Avatar
You need to check the rotor phasing and maybe use a vented cap. is the corrosion white or a orange/rust color?
BBC powered 82 firebird.
Street driven (barely) Best ET no nitrous: 9.42 @142mph , Fogger installed, shooting for low 8s this year
Old Nov 1, 2001 | 12:13 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by 9.0L Firebird:
</font>
9.42 @ 142 mph????? Is that all you got?? J/K....... That is smokin!!
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 1, 2001 | 01:43 PM
its white.
now i just put in a new msd cap (3rd one in 10,000 miles,plus rotor ) and its got build up already? i used msd spark guard direlic grease and new rotor WTF. MAN I JUST MIGHT GO BACK 2 STOCK?
Old Nov 2, 2001 | 06:39 PM
ttt
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
