oil pressure senor relocation/size problem
Old Sep 23, 2005 | 12:33 AM
Blown 346's Avatar
Car: 2000CamaroSS,69 Camaro SS,91 Camaro
Engine: 383
Transmission: TH 400
Axle/Gears: Stock
My current oil pressure sensor on my 91 Z is a manual sensor where it goes in the block and converts to electric at the other end. When I tried to move it from above the oil filter to the back of the block, the threaded hole in the block is a little smaller and the threading is different. Is there a oil pressure sensor that I can but that will replace the setup I have now so it will fit in the back of the block? I know I cant be the only 3rd gen guy with this prob.
Mike
Old Sep 23, 2005 | 05:57 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I have a manual gauge, but it's in the engine bay, see picture at this post https://www.thirdgen.org/techbb2/sho...anifold+block.
Old Sep 23, 2005 | 10:45 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which hole in the back of the block did you try to use?
Old Sep 23, 2005 | 04:16 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
The other oil passage at the back of the block.
Old Sep 23, 2005 | 04:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
So you mean the one at the top of the block near the distributor?
Old Sep 23, 2005 | 07:03 PM
Blown 346's Avatar
Engine: 383
Axle/Gears: Stock
Yes, I actually finally found one at my local Auto Zone. I appreciate all your help.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
