Bad fuel pump testing??????????????
Old Nov 2, 2001 | 03:29 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Im still trying to decide if my fuel pump is bad. If you havent seen another post of mine, in short my car wont start NO fuel pressure, NO Pump noise, NEW relay. I just found my Helms shop manuel too. I was going through the No start chart for the fuel system. It says to find the fuel pump test connector and apply 12 volts to it to see if the pump will come on. The book shows me nothing on how to do this. Where is this connector? What does it look like? How do I go about applying 12 volts to it? Can some one explain in detail how to do this. I suck when it comes to electrical parts.
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Serpentine Setup
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
Old Nov 2, 2001 | 07:16 PM
Vader's Avatar
John,
You can test the fuel pump voltage at the fuel pump relay, on the tan/white wire.
When the ignition is OFF, you can supply power to the fuel pump through the 'G' terminal on the ALDL connector under the dash. Find the ALDL:
Connect a jumper wire to the 'G' terminal, then connect the other end of the wire to a 12VDC+ source.
This supplies power directly to the pump, as diagrammed in the schematic.
If the pump will not operate with this method, either the pump has failed or there is a connection problem in the fuel pump circuit. There is a connector at the tank, as well as a ground connection. If all connections are good and the pump terminals at the tank have 12VDC, the pump needs to be removed. Let's hope you find the problem before then.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 3, 2001 | 11:24 AM
Transmission: 4L60e
Axle/Gears: 9 bolt
I tried the Wire into the G terminal and all I got was the fuel pump relay clicking. looks like its the pump
[This message has been edited by john5.7 87Iroc (edited November 05, 2001).]
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
