motor mounts
Old Sep 24, 2005 | 10:46 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
motor mounts
Hello all,
Have a question about motor mounts, I removed the mounts from the frame and would like to replace the rubber mounts with polyurethane mounts, however I have no idea how to remove the old black rubber mounts. I assumed the new poly mounts would have the steel/metal cover. Any information on this small project would be greatly appreciated.
Brad
Old Sep 24, 2005 | 11:34 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
You have to drill out the spot welds and the clamshell will come apart, then you just need to bolt them back together. Very simple and just be sure you get the new poly mounts in correctly.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
