Hedgasket Question
Old Nov 3, 2001 | 06:49 PM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
Transmission: GM 2004R
Hedgasket Question
if you blow a headgasket and you get water in the oil should you tear down the whole engine or can you flush it out.
The engine has 70k on it.
89 TTA #1415
81 TTA NASCAR
www.krif.com/tta
www.krif.com/gratiot
www.krif.com/st_ignace
<A HREF="http://www.krif.com/woodward
" TARGET=_blank>www.krif.com/woodward
</A>
Old Nov 3, 2001 | 06:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It can be flushed out, but whether that's the right thing to do depends on how long it's been in there. It requires a special flush substance that is specifically made to dissolve the result of mixing oil & AF.
So what's the real situation?
ICON Motorsports
Old Nov 3, 2001 | 08:08 PM
Guest
Guest
Posts: n/a
Depends, is this just a daily driver sorta car or are you gonna beat on it? I had one car that was making milkshakes constantly (till I had the block decked) and I never bothered to tear it down. I sold that car, but its been driven over 40k miles so far with no problems. I have a bearing that saw coolant for maybe a couple miles and for sure was cleaned out, and it has some rather nice pitting in it from the milkshake mix, although I dont think it was hurting anything.
Old Nov 3, 2001 | 10:42 PM
tta1415's Avatar
Car: 1992 Z28
Engine: LC2
its my TTA, been there about two weeks.
89 TTA #1415
81 TTA NASCAR
www.krif.com/tta
</A>
Old Nov 4, 2001 | 02:44 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Well, with all of the stress put on the engine in most TTAs, I am recommending a full tear down and rebuild. I guess you can flush it out and see if it works out in the end, but I just wouldn't take the chance if I were you on a TTA... If the bearings have been damaged by the coolant in the oil already, it will mean big problems later if you just flush it and let her buck.... Better off just doing it right the first time.
My $.02
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 4, 2001 | 02:58 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
2 weeks is about 2 weeks too long.
Coolant eats bearings.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
