While The Carburator Is Off
Old Sep 25, 2005 | 06:44 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
I replaced the intake gaskets last fall, because of a coolant leak.
I see that there is OIL pooling under the throttle lever, as well as in the same spot, but on the right side of the intake manifold.
Because the manifold only handles coolant, fuel/air mixture, and exhaust recirculation, I need to find the source.
It is NOT the valve-cover gaskets.
I believe that the oil is running up the threads of two bolts. Is there a pressurized oil galley under the bolts?
While the carburator is out, I need to remove the two bolts, and teflon-tape them, I guess.
Thoughts?
Thanks Again,
Seth
Old Sep 25, 2005 | 07:08 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I have had the same problem with oil seeping out from the center 2 bolts on each side. My solution was just put a gob of silicone on the bolts before i threaded them in and not a drop since.
Old Sep 25, 2005 | 07:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The intake bolts need to be sealed, some of them run into coolant passages in the heads, and sometimes oil likes to wick up the rest.
Old Sep 25, 2005 | 08:30 PM
Once again, I need to say that you are a wonderful bunch.
Thank you.
Seth
Cleotiz
Jan 6, 2018 08:56 PM
Jynx88
Oct 4, 2015 08:19 PM
fulo
Carburetors
Jul 1, 2001 02:08 PM
fulo
Aftermarket Product Review
Jun 27, 2001 09:16 PM
Zio
Carburetors
Apr 30, 2001 04:47 PM
