Going rate for Vortec heads at the salvage yard?
Old Sep 26, 2005 | 01:07 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
No doubt prices will vary, but can y'all provide any info so I have a little insight if I decide to go shopping?
Old Sep 26, 2005 | 01:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, prices will vary. Check around.
As a baseline, new can be had for $500/pair. http://www.sdpc2000.com/catalog/3129...-Assembled.htm
Old Sep 26, 2005 | 03:48 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
How is $200 for a "good" used pair?
Old Sep 26, 2005 | 03:57 PM
five7kid's Avatar
Will you have to spend more than $300 to make them "like new"?
Old Sep 26, 2005 | 05:12 PM
whoaru99's Avatar
Car: 1991 Z28 w/G92
Engine: 5.7 TPI
That is the consideration. Trying to get details from the yard is like pulling teeth. It's only 40 miles away so I may just go take a look.
I'd guess $300 would be close, but the thing is I *might* be able to include in that $300, or a little more, upgrade to screw-in studs and the guide work to allow higher lift since those mods add the same cost to a new set of Vortecs.
Hopefully, the yard will accept a lower offer too, but maybe not.
If everything comes up to $500-$600, I'd probably go for it. Too much more than that and might just as well go to Trick Flows, or maybe just fix up the stock L98 cast irons with mild porting, etc. since they have only 38K miles. After all, not trying to build 1/4 killer.
No matter which way you go, it seems the costs pencil out very closely once you get to the heads - unless you are talking all out race heads, then it's really big $$.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
nuggie
Aug 25, 2015 01:27 PM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
