Code 42 how to fix?
Old Sep 27, 2005 | 06:39 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Spark plug wire problem please help
So a code 42 came up... I checked the ignition module and had it tested which came up good. One thing i noticed was the spark plug wire from the coil to dist. is kinda loose on the coil. Could this cause a 42? Like normally there is a little resistance when removing plug wires but this came off with no resistance at all. I noticed there is what looks like a place for some kind of clip to lock the wire to the coil. Anyone know what i'm talking about and where i can get one of these clips or if you know a better solution? thanks in advance
Old Sep 28, 2005 | 02:52 PM
trueburton's Avatar
anyone?
Old Oct 2, 2005 | 10:31 PM
Vader's Avatar
Start checking the wiring at the distributor, and to the knock sensor. You can try to "dummy" the knock sensor with a 3900 ohm resistor to see if the code repeats.
Old Oct 3, 2005 | 05:16 AM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
where do you buy that at, radioshack? is there a list of what i can use to trip the computer for different codes?
Old Oct 3, 2005 | 05:18 AM
1meanGTA's Avatar
and by clip do you mean the metal fitting inside the spark plug wire boot that attaches onto the terminal, or a clip that goes over the outside of the boot?
i had the same problem with the wire being loose on my #2 spark plug wire, the fitting had somehow gotten bent and wouldnt stay on like it should. had to take a pair of pliers and bend it back into a circle, took a couple tries to get it to fit.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
64Chief
Sep 12, 2015 08:05 AM
